14 years agoHow to enable tx_clk of the 88e1111
Dir Sir, I'm using Cyclone III development kit. I want using Ethernet IP with mii standard to transfer data via Ethernet. and I want using 100Mbs standard. However, this kit not support tx_clk fro...
14 years agoCheck PHY reset signal, is it high? Did You implement reset bug-fix? Check 88E1111 PDF for proper PHY initialization setup. You need to de-assert reset at required time.
