14 years agoHow to enable tx_clk of the 88e1111
Dir Sir, I'm using Cyclone III development kit. I want using Ethernet IP with mii standard to transfer data via Ethernet. and I want using 100Mbs standard. However, this kit not support tx_clk fro...
14 years agoThen MII should work fine. Are You forcing 1Gbit network to work on 100Mbps? Did You tie 1000Mbps setting in MAC to '0'?
