13 years agoHow to enable the nios 2 IDE?
Hello, I've used the Nios 2 IDE before but now I've installed a new Quartus II Web Edition and the Nios 2 IDE is not available, instead when I start the "Nios 2 build tools for eclipse" from Quartus ...
13 years agoNios IDE is obsolete and it was used up to Quartus version 9 or 10.
Newer Quartus versions only support the Nios SBT for Eclipse. Anyway you should have the same functionalities, although with a different graphical organization. IIRC when I switched from Quartus 9 with IDE to Quartus 11 with Eclipse, it was not so a great problem. Probably you only have to change the windows perspective or browse the menus for the command you need.
