20 years agohow to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash? thanks ! with my ...
20 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- The current flash programmer user guide only shows how to make a target board using the Board Description Editor - not the old mk_target_board utility. I'm sorry but I have no idea where you're going with that.[/b] --- Quote End --- look at ug_nios2_flash_programmer.pdf the chapter : porting the nios II to custom boards you will see at page 2-7 step 15 that it do reffer to old mk_target_board utility. after you will use this utility a target board design will be created that you could open using the sopc. if you will open it you will find there the "more board system setting " tab figure 2-5 of ug_nios2_flash_programmer.pdf shows a picture of that screen with this tab
