20 years agohow to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash? thanks ! with my ...
20 years ago --- Quote Start --- originally posted by dalon@Jan 16 2006, 11:42 AM you could use the nios2-flash-programmer from the command line rather then the ide. the flash programmer user guide has more details. you can program from the command line without a target board configured.
--dalon
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12225)
--- quote end ---
--- Quote End --- Yep - I've tried the command line method and it "seems" to work, although at the end the Verify fails - and sure enough if I dump the memory using a third party tool (FS2) the memory contents compared to the SREC file are incorrect. about half of the bytes are wrong. It almost seems like timing, but I can R/W to flash memory manually using the FS2 command line interface to Nios...
