20 years agohow to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash? thanks ! with my ...
20 years agoI have the same exact problem with the new and improved flash programmer. You are supposed to be able to just create a board description and only need to designate the flash devices in the "Flash Memory" tab. After this, the programmer is supposed to work!! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif
Not only does the programmer NOT work, but once I made a board description, my SOPC system no longer compiles! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif The Flash Programmer GUI gives the error message: " the target board must define at least one hardware image to program an fpga configuration." As for the post by Ilan - I don't have any tab anywhere called "more board system setting tab". I also tried doing everything from the SDK shell where I had some success programming - but the verify fails!
