20 years agohow to download the FPGA configuration data in to
hi ,everybody.there is a CFI(common flash interface)flash on my board ,but i only use it to store my software data! how to download the FPGA configuration data in to the flash? thanks ! with my ...
20 years agoto download ur hardware fpga config code... u hav to use the e command to erase the hardware section (user portion of flash).. then use r command to relocate the stack pointer to the starting of the hardware section, then
nr -p <com port> XXX.hexout u will now prog ur fpga hardware config to ur hardawre section of the flash memory
