21 years agoHow to do IUL in SOPC 4.2?
I'm porting a Legacy .ptf to NiosII/HAL/IDE/The Works. I see that Interface To User Logic has been tossed in the Legacy bin. What is the new way? I would think Create New Component, but I...
21 years agoKenland,
There shouldn't be anything wrong with using the IUL, but the future is definitely with the Component Editor. Also, I don't know what you mean by "no timing" in the CEd. It's there, you have to add your HDL files and then connect up your Avalon ports. Once you've done that, you should see the timing, that you're looking for, for each of the ports that you define. Hope this helps. - slacker
