11 years agoHow to divide tasks to be done by Nios II processor & Logic elements?
Hi all, I have a complete working project where I use MATLAB/Simulink with coding in S-function Level 2 as well as Simulink blocks. Now I would like to convert the above project into...
11 years ago --- Quote Start --- How long is a piece of string? Really it is balance between resource usage and processing speed. Code in C will typically be slower but use less resource than the same in VHDL. Very small blocks of VHDL can quickly perform operations that take quite a few code instructions. --- Quote End --- Hi dsl, thanks for your reply... the coding (which I've previously done in Matlab/Simulink) is approximately 500 lines Do you mind to give me links/resources in order to learn how to determine/divide the workloads for Nios II processor (C language) and logic elements (VHDL)? I am curious how others determine the workload for Nios II processor (C language) and logic elements (VHDL)? or am I just the only one having this problem??
