11 years agoHow to divide tasks to be done by Nios II processor & Logic elements?
Hi all, I have a complete working project where I use MATLAB/Simulink with coding in S-function Level 2 as well as Simulink blocks. Now I would like to convert the above project into...
11 years ago --- Quote Start --- Everything, that needs computing power, goes to the part with logic elements and VHDL, simple tasks like rs232 communication go to C code on Nios II. --- Quote End --- Thanks for your reply, linas... Correct me if I am wrong as I am really a beginner here, I thought I want the C code to do the tedious tasks instead of simple tasks cause VHDL tends to become very long for complicated task due to its low level language sorting algorithm - if-else comparison - switching on and off - Can I assign the switching signals array in C language, then send one by one bit to the switching circuits represented in logic elements (VHDL)? I think I still don't quite get the idea, sorry, do you mind to give me links/resources in order to learn how to determine/divide the workloads for Nios II processor (C language) and logic elements (VHDL)? Appreciate your time
