rshal2
7 years agoHow to disable MAC-PHY communication ?
Hello, I am not sure why do we get "TSEMAC SW reset bit never cleared!" : We are connecting the FPGA to network switch, (unmanaged switch), so we removed all communication with phy , by disabling M...
FawazJ_Altera
7 years agoHello,
The software terminal output shown in your description is coming from a nitchestack application right? My point here is, you cannot run Nitchestack without phy.
The TSE expects a clock to come from the phy. without this clock, you will not get rid of this reset issue.
May I know what is the intention of having phy-less system?
Are you going to send data through ethernet cable?
Thank you.
rshal2
7 years agoHi,
I am using Marvell switch.
This switch has un-managed mode, i.e. mode in which the switch starts operating without any need for configuration.
I think this is not an issue of nitchestack limitation , I've commented out all it's trials to communicate with phy.
The limitation seems to be purely related to TSE.
