rshal2
7 years agoHow to disable MAC-PHY communication ?
Hello, I am not sure why do we get "TSEMAC SW reset bit never cleared!" : We are connecting the FPGA to network switch, (unmanaged switch), so we removed all communication with phy , by disabling M...
FawazJ_Altera
7 years agoHello,
I will investigate more about your problem. In the mean time, would you please confirm the clock connections that are going to TSE, including the ones that are coming from the PHY?
thank you
- rshal27 years ago
Thank you very much, It's very much appreciated.
As to the clocks, the FPGA internal clocks seems to be OK.
Is there a specific clock that we should check ?
nios_eth_tse_pcs_mac_tx_clock_clk => emac_tx_clk, nios_eth_tse_pcs_mac_rx_clock_clk => rgmii_rx_clk,I've validated with signal tap that emac_tx_clk is correct (25M clock for 100M ethernet)
as to rgmii_rx_clk, I see no clock, does it explain the mac reset issue ? not sure
Thank you
