20 years agoHow to disable IP header and UDP checksum
I am implementing my own UDP stack by manually filling the entire ethernet frame, byte by byte. I ignored the checksum fields in the frame by leaving them as zero. However, the receiving end is disca...
20 years agoYes at least you have to calculate the checksum for the ip-frame
