19 years agoHow to definition "SYSTEM_BUS_WIDTH"?
Hi,everybody:
I'm write a custom logic on DE2 board. Within IO header file for the NIOS toolchain there is a definition 'SYSTEM_BUS_WIDTH'. Can anybody tell me where this is defined, I have done a search for the string and found nothing so far. PS: The message as following: NiosQ@localhost ~/NiosQ_program $ nios2-linux-uclibc-gcc hello_altera_avalon_pwm.c -o hello_altera_avalon_pwm -elf2flt hello_altera_avalon_pwm.c: In function `main': hello_altera_avalon_pwm.c:42: error: `SYSTEM_BUS_WIDTH' undeclared (first use in this function) hello_altera_avalon_pwm.c:42: error: (Each undeclared identifier is reported onl y once hello_altera_avalon_pwm.c:42: error: for each function it appears in.) hello_altera_avalon_pwm.c: In function `print_error': hello_altera_avalon_pwm.c:86: error: `SYSTEM_BUS_WIDTH' undeclared (first use in this function) NiosQ@localhost ~/NiosQ_program $ Thank you for your help. Regards NiosQNo RepliesBe the first to reply
