20 years agoHow to deal with the route in Linux
the next figure is my network ----<--Extern Network(ADSL module)(IP base : 192.168.1.1 netmask 255.255.255.0 --> | | |______><Route (IP base 192.168.2.1 netmask 255.255.25...
20 years agoNow I input the next command
<div class='quotetop'>QUOTE </div> --- Quote Start --- 127.0.0.0 * 255.0.0.0 U 0 0 0 lo# ifconfig eth0 192.168.2.12 Heth0:PHY 100BaseT eth0:PHY Full Duplex# route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo[/b] --- Quote End --- i add the route <div class='quotetop'>QUOTE </div> --- Quote Start --- # route add default gw 192.168.2.1# route -n Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0 127.0.0.0 0.0.0.0 255.0.0.0 U 0 0 0 lo 0.0.0.0 192.168.2.1 0.0.0.0 UG 0 0 0 eth0[/b] --- Quote End --- when i input the ping <div class='quotetop'>QUOTE </div> --- Quote Start --- # ping 192.168.2.102 PING 192.168.2.102 (192.168.2.102): 56 data bytes --- 192.168.2.102 ping statistics --- 3 packets transmitted, 0 packets received, 100% packet loss# ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes 84 bytes from 192.168.2.1: icmp_seq=0 ttl=128 time=10.0 ms 84 bytes from 192.168.2.1: icmp_seq=1 ttl=128 time=0.0 ms 84 bytes from 192.168.2.1: icmp_seq=2 ttl=128 time=0.0 ms --- 192.168.2.1 ping statistics --- 3 packets transmitted, 3 packets received, 0% packet loss round-trip min/avg/max = 0.0/3.3/10.0 ms# [/b] --- Quote End --- in my computer I input the ipconfig <div class='quotetop'>QUOTE </div> --- Quote Start --- Ethernet adapter 本地连接: Connection-specific DNS Suffix . : private IP Address. . . . . . . . . . . . : 192.168.2.102 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.2.1[/b] --- Quote End --- so I ping the board <div class='quotetop'>QUOTE </div> --- Quote Start --- C:\Documents and Settings\alexliu>ping 192.168.2.12 Pinging 192.168.2.12 with 32 bytes of data: Reply from 192.168.2.12: bytes=32 time=1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Ping statistics for 192.168.2.12: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 1ms, Average = 0ms[/b] --- Quote End --- it very strange . I don't know how to deal with the problem . pls help me ! thanks !!!
