20 years agoHow to deal with the route in Linux
the next figure is my network ----<--Extern Network(ADSL module)(IP base : 192.168.1.1 netmask 255.255.255.0 --> | | |______><Route (IP base 192.168.2.1 netmask 255.255.25...
20 years agoHI hippo
I have select the next config [* ] IP: advanced router but now i find a strange things . when i use the next command in my PC (win-xp) <div class='quotetop'>QUOTE </div> --- Quote Start --- C:\Documents and Settings\alexliu>ping 192.168.2.12 Pinging 192.168.2.12 with 32 bytes of data: Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Reply from 192.168.2.12: bytes=32 time<1ms TTL=64 Ping statistics for 192.168.2.12: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms[/b] --- Quote End --- but I use the next command in my Board (EP2C35) <div class='quotetop'>QUOTE </div> --- Quote Start --- # ping 192.168.2.102 PING 192.168.2.102 (192.168.2.102): 56 data bytes --- 192.168.2.101 ping statistics --- 6 packets transmitted, 0 packets received, 100% packet loss# ping 192.168.2.1 PING 192.168.2.1 (192.168.2.1): 56 data bytes 84 bytes from 192.168.2.1: icmp_seq=0 ttl=128 time=10.0 ms 84 bytes from 192.168.2.1: icmp_seq=1 ttl=128 time=0.0 ms 84 bytes from 192.168.2.1: icmp_seq=2 ttl=128 time=0.0 ms 84 bytes from 192.168.2.1: icmp_seq=3 ttl=128 time=0.0 ms 84 bytes from 192.168.2.1: icmp_seq=4 ttl=128 time=0.0 ms --- 192.168.2.1 ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss round-trip min/avg/max = 0.0/2.0/10.0 ms[/b] --- Quote End --- so I cann't find the reason . why I can connect the router(192.168.2.1) but when i connect my pc(192.168.2.102) ,i cann't connect it .
