20 years agoHow to deal with the route in Linux
the next figure is my network ----<--Extern Network(ADSL module)(IP base : 192.168.1.1 netmask 255.255.255.0 --> | | |______><Route (IP base 192.168.2.1 netmask 255.255.25...
20 years agodo you config your board as following?
ifconfig eth0 192.168.2.12 eth0 you can use "ifconfig eth0 192.168.2.12". if the two device in the same subnet. The ip pocket won't transmit through the route
