21 years agoHow to deal with the additional address line?
I use IUL in SOPC to add a memory slave peripheral.I add 18 address line (add[17..0]) and then in the Quartus it appears add[19..0], I read the datasheet of AvalonBus about Dynamic bus sizing. B...
21 years agowhich version of quartus and Nios are you using ?
what are your settings of user logic in sopc builder (mainly databus width ?)? with dynamic bus sizing: 8 Bit Databus : connect A0..Ax of RAM to A0..Ax of NIOS ADDRESS BUSS 16 Bit Databus : connect A0..Ax of RAM to A1..A(x+1) of NIOS ADDRESS BUSS 32 Bit Databus : connect A0..Ax of RAM to A2..A(x+2) of NIOS ADDRESS BUSS in case of 16 Bit Databus leave A0 of NIOS ADRESS BUS unconnected in case of 32 Bit Databus leave A0+A1 of NIOS ADRESS BUS unconnected REMARK: Altera told me that there was a change in the addressing scheme with NIOS 1.1 for native slaves. Table 15 Page 100 of Avalon Bus Specification should be corrected as following: Alignment | Master Width | Slave Width | A[0] of Slave is connected to Byte Address Bit Number native | 32 | 32 | A2(NIOS1.0) A2(NIOS1.1) native | 32 | 16 | A2(NIOS1.0) A1(NIOS1.1) native | 32 | 8 | A2(NIOS1.0) A0(NIOS1.1) dynamic | 32 | 32 | A2 dynamic | 32 | 16 | A1 dynamic | 32 | 8 | A0 PLEASE correct me if i tell something wrong!
