12 years agoHow to create bootable VxWorks SD-Card?
Hey! I'm very new in this topic and i read a lot to come into it. But i still have some problems. I have a Arrow SoCkit Cyclone V Board and the goal is, to get a working VxWorks System on it....
12 years ago@Bevo
I knew this Document, but the Images/ Files unforthantly don't work for the Arrow Board. Nevertheless I followed the Instructions. I builded my own Preloader with BSP-Editor and made my own SD-Card with FAT-Partition. But the Problem is like above. I tried to use u-boot commands to start the bootrom.bin manually. I've loaded it so several adresses in cache and tried to execute them with bootm to this adress. The error is: "Wrong Image Type for bootm command - ERROR: can't get kernel image!" Thats why I tried to find a way to add the bootvx command as @ngoodger told. But I can't find out how to do that. @ngoodger How you added the command. I added "#define CONFIG_CMD_ELF" to "config_cmd_default.h" and recompiled my whole preloader, but the command didn't appear. Can you give me some further advices?
