16 years agoHow to create and store data table in Flash
I want to create a few tables of data and store the tables and specific locations in off-chip Flash memory. The Linker would easily allow me to do this, but I am porting legacy code from long ago and...
16 years agoYou can have only one of those two lines. If you use the pointer with the address, you would have to program the values in the flash separately instead of defining the initial values in your code.
You may be able to fix both the values and the addresses by using a custom linker script but it's not the easiest thing to do...
