21 years agohow to create a directory on the board?
Hi, I have a stratix 1s10 with a uclinux. I'd like to create a directory (mkdir new_directory) but I don't have the permission. I think it's a question of right, but ... I don...
21 years agoHi John,
You'll need to enable jffs2 in the kernel configuration, then create your own jffs2 image using the mkfs.jffs2 utility. You can get the sources from: http://www.psyent.com/download (http://www.psyent.com/download) The sources at this site were ported for use under cygwin ... but you'd be doing yourself a favor (at least for the time being) to build the utility under linux -- as the cygwin version doesn't do a good job with some of the file attributes. Regards, --Scott
