20 years agoHow to copy files from Hard disk to Compact flash
Hi, can anybody tell me how to access a hard disk and a compact flash disk to transfer data between the two. I am using Win XP, Nios II v5.0, µClinux 1.4 and a Stratix Pro edition (1s40). ...
20 years ago --- Quote Start --- originally posted by mfm+mar 6 2006, 10:46 am--><div class='quotetop'>quote (mfm @ mar 6 2006, 10:46 am)</div>
--- quote start ---
<!--quotebegin-mfm@Mar 5 2006, 11:05 PM hi hippo,
can you please explain me how to use that ftpd, i exectuted it then typed help to get a number of commands i can't figure out.
thnx
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13134)
--- quote end ---
--- Quote End --- Hi, finally I made it ))))))) Well, I've connected to my board through another computer running Linux. I executed the ftp command, turned off the passive option and I executed the put command to copy files from the computer to the CF mounted on the board. And it works fine. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=13157)</div> [/b] --- Quote End --- Hi MFM Could you tell me something more about this? what fs type of your CF card. And how to turn off the mode. On linux platform what commands we need to used. Thanks!
