20 years agoHow to copy files from Hard disk to Compact flash
Hi, can anybody tell me how to access a hard disk and a compact flash disk to transfer data between the two. I am using Win XP, Nios II v5.0, µClinux 1.4 and a Stratix Pro edition (1s40). ...
20 years agoVia network through cifs (which is smb-extended)
mount -t cifs //server/share /mnt ..... However, it is a long way to reach. You need to enable cifs support in kernel. You need mount.cifs. There is a port of samba in uClinux-dist. But the port did not generate mount.cifs automatically. You have to do some work on it. I am not good at network. And can't not help you a lot on this. But if you remember, I did suggest you to work on Linux and build tools/kernel/apps. Why? You will understand when you want to something that is not out the box. As was suggested by Scott, using ftp server/client is a easier approach. There is a ftpd in Microtronix's port. Setup the ftpd on nios2, and upload files to nios2 from XP.
