20 years agoHow to copy files from Hard disk to Compact flash
Hi, can anybody tell me how to access a hard disk and a compact flash disk to transfer data between the two. I am using Win XP, Nios II v5.0, µClinux 1.4 and a Stratix Pro edition (1s40). ...
20 years ago --- Quote Start --- originally posted by smcnutt@Mar 3 2006, 04:57 PM hi mfm,
> i'm looking for a connection through network to connect with my hard disk
depending on your requirements, you can use tftp or nfs from a bootloader like
u-boot or redboot. you might also consider an ftp client on the nios side.
regards,
--scott
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13095)
--- quote end ---
--- Quote End --- Hi Scott, thnx Scott for your reply, but can you explain it a little bit more, beside this I found some topics talking about using the CIFS network file system to access a shared windows directory, have you any idea about ?
