How to convert from .pof to binary?
Hi all,
I've manged to combine the .sof and my boot-loader into .pof file (via the convert file option in quartus) - and everything is good. However, for remote updates I'd like to be able to write directly to the EPCS4, which I can do - but I'd need to be able to get the .pof file that I usally program from quartus into a format I understand (binary?) to be able to write some code for the NIOS to write it into the EPCS4. A means to convert the .pof file to a binary (.rbf?) file would probably do - but I don't know if this is possible? Is this possible? Thanks, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif10 Replies
Not shure that I got you right, but
You can create a .rbf file with the "convert programming file" option in the file menu. - Altera_Forum
Or use quartus_cpf to do it from the command line.
See `quartus_cpf --help` for more details. - Altera_Forum
the convert programming file can only generate a .rbf from a .sof.
i must convert my design to a .pof, because I add in my loader.hex code using that convert-programming file.... so, I can generate a .pof with my .sof and the .hex file located at the end of the device - good. and I can generate a .rbf of the .sof (only). however, there is no combination of the tools/file-types I have come up with to get the .pof into a .rbf (or even intel hex which I could then convert with a wee program). http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif - Altera_Forum
What about `quartus_cpf -c <project>.sof <project>.hexout`?
You can then use nios2-elf-objcopy to convert the hexout to srec if that's what you'd rather have. It works for .pof files too, although I haven't verified that it creates the correct output. - Altera_Forum
Thanks for the suggestion. Getting data around sometimes seems like a big riddle - I will try and see what new combinations of file translators/etc gets the end result......
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif - Altera_Forum
I got a reply from a separate mySupport posting... However the chap says that unfortunatly this cannot be done. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
What I can maybe do is write a nios program to read its serial memory and fire it back at me through the serial port to capture it? I wonder though - if there is documentation to explain the header formats for a .pof? I don't care at all for the file format other than to get the bytes to write to the serial memory? In my simple mind all I need to the rules for skipping through the .pof file and extract the binary lumps accordingly? Any ideas folks? The riddle of file-formats continues..... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif - Altera_Forum
Hi all,
I have converted the .sof to a .rbf and written it to the EPCS device. But the FPGA will not boot? Now, I have verified that the data is written down correctly - and also that the bits are reversed for each byte for example - but no boot. Is a .rbf file of a .sof okay to write straight to address 0 onwards in the EPCS4? Thanks http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif - Altera_Forum
> But the FPGA will not boot? This won't work ... the contents of an rbf and what goes into the epcs device are not the same ... almost the same ... but they're not identical :-( As I recall, the data packet contents in the pof has what you want ... the magic "register" bits et. al. I have some old code laying around somewhere that parses pof/sof and can extract the necessary bits ... if I can find it, I'll post it. Regards, --Scott - Altera_Forum
nice one scott. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi Joe,
I have some good news and some better news ... the good news is I found the code and can send it to you if you like. The better news is you don't need it ;-) 1. Use sof2flash 2. Use objcopy as wombat suggested E.g.: $ sof2flash --epcs --input=proj.sof --offset=0x0 --output=proj.flash $ nios2-elf-objcopy -I srec -O binary proj.flash proj.bin As an aside, the logical address/data packet in the pof is _NOT_ compressed. Using the steps above however will produce a compressed bitstream (as appropriate). Regards, --Scott
