19 years agoHow to control DMA core?
I am doing a project which need to use PCI core. Since I am not going to use the NiosII, so DMA become my option. My question is: how can I control the DMA to read the data from PCI and write i...
19 years ago --- Quote Start --- originally posted by ohaltera@Jan 17 2007, 08:46 PM i am doing a project which need to use pci core. since i am not going to use the niosii, so dma become my option.
my question is: how can i control the dma to read the data from pci and write it to ddr2? or how can i read the data from ddr2 and write it to pci? or probably i don't need to control the dma at all? i need to give the source adderss and destination address to the dma, right?
correct me if my idea is wrong.
any opinions are welcomed.
thanks.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=20665)
--- quote end ---
--- Quote End --- First, how do you plan to control the DMA engine? From the PCI bus? Second, I gather you want the board to master both PCI reads and Memory writes or are you just trying to access memory from the PCI bus? Mike
