15 years agoHow to connect UART and DMA?
In the document "Embedded Peripherals IP", I find following paragraph: "The UART core's Avalon-MM interface optionally implements Avalon-MM transfers with flow control. Flow control allows an Aval...
15 years agoThe problem is solved.I just change the destination address. Use (void *)(UART_Base+1)to replace destination_buff_ptr in the code "rc = alt_dma_txchan_ioctl(txchan, ALT_DMA_TX_ONLY_ON, destination_buff_ptr". But I don't understand why, because the register is 32 bit width.....
