19 years agohOW to connect the DM9000 inDE2
Dear ALLL I have a DE2 board. Now I want to use the DM9000. I want to know how to connect it to NIOSII . Beacuse I find the uClinux have a drive form DM9000. How to do it when I use the driv...
19 years ago --- Quote End --- I looked at your pinging post. I think you did not ping the right IP becauase the last number is .2 not .20, also I have some questions; 1.) When you hook up the ethernet do you get lights flashing straight away. 2.) If you go ifconfig eth0 down do you still get the leds flashing--> This should not happen. This is just to get some more info about your design. regards, <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19177)</div> --- Quote End --- Dear madman23 Now I use the ethereal to capture the netwrok . I find My borad can send the next inforamtion <div class='quotetop'>QUOTE </div> --- Quote Start --- "No.", "Time", "Source", "Destination", "Protocol", "Info" "1", "0.000000", "192.168.1.21", "Broadcast", "ARP", "Who has 192.168.1.3? Tell 192.168.1.21" "2", "0.000023", "192.168.1.3", "192.168.1.21", "ARP", "192.168.1.3 is at 00:11:25:d2:24:ac" "3", "0.999980", "192.168.1.21", "Broadcast", "ARP", "Who has 192.168.1.3? Tell 192.168.1.21" "4", "1.000003", "192.168.1.3", "192.168.1.21", "ARP", "192.168.1.3 is at 00:11:25:d2:24:ac" "5", "2.999923", "192.168.1.21", "Broadcast", "ARP", "Who has 192.168.1.3? Tell 192.168.1.21" "6", "2.999946", "192.168.1.3", "192.168.1.21", "ARP", "192.168.1.3 is at 00:11:25:d2:24:ac" "7", "3.999902", "192.168.1.21", "Broadcast", "ARP", "Who has 192.168.1.3? Tell 192.168.1.21" "8", "3.999926", "192.168.1.3", "192.168.1.21", "ARP", "192.168.1.3 is at 00:11:25:d2:24:ac"[/b] --- Quote End --- 192.168.1.21 is the board . 192.168.1.3 is my PC . So I think the dm9000 can send the packets to my pc , the baord can't receive the packets . I have check the sch and PCB . It is the same as the reference of DE2 .
