19 years agohOW to connect the DM9000 inDE2
Dear ALLL I have a DE2 board. Now I want to use the DM9000. I want to know how to connect it to NIOSII . Beacuse I find the uClinux have a drive form DM9000. How to do it when I use the driv...
19 years ago --- Quote Start --- originally posted by alex.liu@Nov 5 2006, 03:07 PM madman23 thank you
now i think you maybe understand my question.
i have do it ok in my de2 board .
i design a board using dm9000, the sch is the same to de2 .
linux can be run in the same network , but when i use my new board . i find the led2 keep flash ,i don't know what's wrong . hardware ? sotfware?
could you help me ! thanks !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19175)
--- quote end ---
--- Quote End --- I looked at your pinging post. I think you did not ping the right IP becauase the last number is .2 not .20, also I have some questions; 1.) When you hook up the ethernet do you get lights flashing straight away. 2.) If you go ifconfig eth0 down do you still get the leds flashing--> This should not happen. This is just to get some more info about your design. regards,
