"How to Connect 'Interrupt Sender' to Avalon Address in Platform Designer (Quartus Prime Pro)?"
Thank you for your response!
We couldn't locate a parameter corresponding to the "Interrupt Request" of our "Custom HDL Module" in the system.h file generated by the Platform Designer. Currently, if we use the "IRQ Number" assigned to this interrupt in the Platform Designer as a hard-coded value in our embedded software code, it works without any issues.
However, we would prefer a more flexible solution by associating a parameter in system.h with this interrupt. This approach would avoid manually updating the hard-coded value if we modify the Platform Designer in the future.
As mentioned earlier, in previous versions of Quartus software, we could achieve this using the "Associated addressable Interface" feature, which is unfortunately no longer available in Quartus Prime Pro.
Best regards.
