12 years agoHow to connect CFI with NIOS cpu in SOPC?
Dear everyone, I want to know how to connect CFI with NIOS cpu in SOPC? Using Avalon-MM Tristate Bridge? Hope that you can provide me an example project, Thank you very much!
12 years agoYou'll want the Nios II instruction and data master to connect to the tri-state bridge which then masters your CFI flash component. If you look around for example designs for the Stratix/Cyclone 1-3 Nios II dev boards you'll probably find lots of examples. Moving this to the Nios II forum section so that you'll get more embedded folks reading this.
