20 years agoHow to connect a VHDL file to existing NIOS up
This is my problem: I designed a NIOS Microprocessor using the SOPC builder; added it to the .bdf file and tested it. It works fine. Now I want to add a .vhdl file to this existing project wh...
20 years agoHere's a good place to look: http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf)
This document will list off what signals you need to have when using component editor to create particular components. Usually for most interfaces you need these: address, data, chipselect, readdata, writedata, read, write, waitrequest (non-fixed latency), clk, reset (this set of signals is not appropriate for a tri-state components or is not enough for advanced components)
