20 years agoHow to connect a VHDL file to existing NIOS up
This is my problem: I designed a NIOS Microprocessor using the SOPC builder; added it to the .bdf file and tested it. It works fine. Now I want to add a .vhdl file to this existing project wh...
20 years agoHi Mike,
if i use p/io and hook them up so that i can use them in the vhdl modules. but is it possible to interrrupt the processor using same pios or how to interrrupt the processor from a vhdl module. regards prasad
