21 years agoHow to compile/load uClinux to 2s60 demo board?
I just downloaded the latest distribution of uClinux and installed it on my pc. I am also running into the same problem as a few others have -- namely there is no "linux" subdirectory in the ..\alte...
21 years agoI have also got a STRATIX II board.
Yust run quartus en open a example desing. Then run SOPC builder ( double click on the symbol block ) then add / remove components a you like. then run sopc builder and exit. Quartus ask to update the block, do that. Then compile your compleet desing with quartus. You see that your *.sof file ha been changed. Now used this new desing for reference when you create a new kernell/filesytem in the IDE program
