21 years agohow to compile nios2 gcc?
I would like to modify the nios2 gcc. Could some one tell me how to compile nios2 gcc or where to find the documents about how to compile and install the nios2 gcc? Thanks!!
21 years agoCloud,
We really do not recommend that you try to re-build the compiler unless you've done it before. There are no documents on how to build the nios2 gcc compiler. However there are generic documents which exist on building gcc, these can be found at http://gcc.gnu.org/install/ (http://gcc.gnu.org/install/) once again we would really warn you off going down this route. If however you do then please don't post any questions here, you will have to ask for help on the gcc mailing lists.
