21 years agoHow to compile driver in Nios2uclinux
Hello everyone, In Microtronix nios2uclinux,How can I compile my device driver? through the nios2 IDE or other ways?And can I use the module or must add the program into kernel? ...
21 years agoIt's also possible to compile your driver as a kernel module outside of the source tree. Take a look at:
lwn: driver porting (http://lwn.net/articles/21823/) The only thing that you would have to do differently to get it working is to specify an output directory on the make commandline from within the example makefile....
KDIR = $(KERNEL_PlUGIN)/linux-2.6.x
BUILDDIR = $(ECLIPSE_WORKSPACE)/kernel_project/build
$(MAKE) -C $(KDIR) O=$(BUILDDIR) SUBDIR=$(PWD) modules
... After compiling the module, you can upload it to your filesystem or copy it into a filesystem project and re-upload the filesystem project.
