21 years agoHow to compile driver in Nios2uclinux
Hello everyone, In Microtronix nios2uclinux,How can I compile my device driver? through the nios2 IDE or other ways?And can I use the module or must add the program into kernel? ...
21 years agoIn the kernel tree ( should be something like "C:\altera\kits\nios2\bin\eclipse\plugins\com.microtronix.nios2linux.kernel_0.1.5\linux-2.6.x\drivers" but it depends on where you installed the NIOS IDE) add your driver code files to the appropriate directory (char for instance if you are writing a char driver).
In the makefile for that directory add the object file for your driver to the line "obj-y += ..." (eg if your code is in mydrv.c you should put mydrv.o at the end of that line). Compile your kernel as usual. This will get you going, but this will put your driver directly in the kernel (it will not be a module). To add modules or make your driver appear in the kernel configuration menu you will have to ask again. Tuck
