20 years agohow to communicate with a new external peripheral
sorry, my english is poor. i want to connect with Nios II system(SOPC Builder) and an altsynram(User Logic) now, i want to write a data (16 signed bits) to altsynram(data bits=16, addr bit...
20 years agoHi kewang,
Your avalon interface must meet the timing requirements of your altsyncram. There are many ways to do this ... and the appropriate solution will depend on your particular requirements. The easiest is to add some glue logic that takes advantage of the avalon waitrequest signal -- to make sure the avalon side meets the minimum setup and hold times for your ram. See http://www.altera.com/literature/manual/mnl_avalon_spec.pdf (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) Regards, --Scott
