21 years ago
how to change the class file for the sram
I wanna use a sram named is61lv25616 in nios system!
so I change the parameters in up3 sram!
the parameters in up3 sram is:
WIZARD_SCRIPT_ARGUMENTS
sram_memory_size = "128";
sram_memory_units = "1024";
sram_data_width = "16";
SLAVE s1
PORT_WIRING
PORT data
width = "16";
is_shared = "1";
direction = "inout";
type = "data";
PORT address
width = "16";
is_shared = "1";
direction = "input";
type = "address";
the result I changed is:
sram_memory_size = "512";
sram_memory_units = "2048";
SLAVE s1
PORT_WIRING
PORT data
width = "16";
is_shared = "1";
type = "data";
PORT address
width = "18";
is_shared = "1";
type = "address";
but after I gererate the system ,the the address in symbol is from 19 to 0, but I think 18 to 0 is right!
who can help me?????
1 Reply
    Hi sybase2008,
    That's not a good idea to modify the sram component of up3. You can make that sram component under SOPC component editor, very easy.
    Up3 board has some special feature: besides databus. Its address bus is shared by sram, sdram, flash, etc. A multiplexer is needed in the top design. Up3 board may be different from your board, so just get ride of sram_up3.
    Cheers,
