20 years agoHow to Change NIOS II IDE Console Baud Rate?
Hello all, I am new to the forum and to NIOS Processors. Does anyone know how to change the NIOS II IDE Console Baud Rate? Its default setting to download data is 115,000 Baud, and I woul...
20 years ago --- Quote Start --- originally posted by luca@Mar 8 2006, 10:03 AM mantrasu,
when you select your sopc uart in run... -> nios ii terminal communication device
the ide should read your uart baud rate and adapt the console accordingly.
never tried, so please post your results!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13226)
--- quote end ---
--- Quote End --- Hello Luca, Thank you for the response. I have not had any luck with just the settings in the Run dialog box. I have set up the UART to be the STDin/out/err/etc., and in SOPC Builder it is a fixed baud rate of 4800, and the IDE console says it is trying to connect at 115,200 baud whenever I try to run or debug the code. I will try it with a different project to see if I can get different results. Maybe it is some other setting in the IDE I haven't found. I have talked to someone else in person though, and said they were having problems connecting to the IDE at different baud rates too. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif thanks again!
