20 years agoHow to Change NIOS II IDE Console Baud Rate?
Hello all, I am new to the forum and to NIOS Processors. Does anyone know how to change the NIOS II IDE Console Baud Rate? Its default setting to download data is 115,000 Baud, and I woul...
20 years ago --- Quote Start --- originally posted by mantrasu+mar 8 2006, 10:34 am--><div class='quotetop'>quote (mantrasu @ mar 8 2006, 10:34 am)</div>
--- quote start ---
i am new to the forum and to nios processors.[/b]
--- quote end ---
welcome :-)
<!--quotebegin-mantrasu@Mar 8 2006, 10:34 AM does anyone know how to change the nios ii ide console baud rate? its default setting to download data is 115,000 baud, and i would like to change it to 4800 baud so that it is compatible with the uart i have set up already for a serial peripheral. i cannot find a setting in the ide menus nor in the ide help files. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif --- Quote End --- No promises, but this may be worth a try.... 1) Make a backup of your Altera-supplied template folder "..\altera\kits\nios2_51\examples\verilog\<kit>..." 2) Open your project in SOPC builder 3) Find your serial port's UART and rdo right-click->edit 4) At the Baudrate dropdown, select 4800 baud. You may also wish to check the "make baudrate selectable' checkbox, but its a good idea to try only one change at a time 5) Hit Finish 6) Hit Generate (& make a cup of tea) At this point it may be a good idea to recompile your project in Quartus II (but I don't know). 7) load up your new PTF file into the board and try again Good luck
