20 years agoHow to bypass checksum calculation?
To speed up transmition of udp packet, i tried to bypass the checksum calculation by modifying 2 lines of file opt.h in folder: ...\components\altera_lwip\UCOSII\src\downloads\lwip-1.10\src\in...
20 years agoHi Danny,
Thank you for your help. I think I have got a key in my case and like to share with you and other friends. My system is based on a IS10 DEV kit from Altera, uses Nios2/f cpu. UDP transmition runs on ucos II as a task. My work is to collect image(320*256 pixels,16bit) into SDRAM and send they to a host. Here is my UDP routine: # define TOTAL_UDP 160 // total packets, 1K bytes a packet# define UDP_EACH_DATA 1024 // bytes,# define UDP_PAYLOAD_BYTES UDP_EACH_DATA+2 // add index number of packet volatile int num_udp_completed=0; void SSSUDPSendTask() { struct netconn *conn; struct netbuf *buf; struct ip_addr addr; INT8U err; unsigned short* udp_packet_addr; unsigned int udp_addr_offset; int j; /* confique connection to host as UDP */ conn = netconn_new(NETCONN_UDP); /* set up the IP address of the remote host */ addr.addr = htonl(HostIPAddress); /* connect the connection to the remote host */ netconn_connect(conn, &addr, HostUDPPortNum); /* create a new netbuf */ buf = netbuf_new(); while(1) { // wait for a semaphore from DMA task OSSemPend(CAMDMAFinishSem,0,&err); for(j=0;j<4;j++) // send 2k pixels each time { /* set the base and offset address of UDP packet */ udp_addr_offset = UDP_EACH_DATA * num_udp_completed; udp_packet_addr = (unsigned short*)(dma_data_base + udp_addr_offset-2); /* insert index before data */ *udp_packet_addr = num_udp_completed; /* reference the data into the netbuf */ netbuf_ref(buf, (unsigned char*)udp_packet_addr, UDP_PAYLOAD_BYTES); netconn_send(conn, buf); num_udp_completed++; } if (num_udp_completed == TOTAL_UDP) { num_udp_completed = 0; } } //while(1) } Now in my system the time spending on collecting 100 frame pictures has decreased from 40.5 to 7 sec via following steps. (1) move phrases (netconn_new().. buf =) to outside while(1) loop as above routine shows. this makes the time drop from 40.5 to 20.2 seconds. (2) next step, use your udp.c routine, the time reaches 15.4 sec. i doubt if the lwip calculates checksum for each element of data. (3) change the compile option, configuration, from Debug to Release. that is in c/c++builder of properties of myproject and myproject_syslib. the time is 7 sec. The result is not bad although something still let me maze. Thanks to you again, Cheers, Johnd
