19 years ago
How to build uclinux to DE2 board ,please help!
hi,everybody,
I have a DE2 board and I want to install uclinux onto the board as the OS,but
I got some difficulties,would you please info me some files or give me some links
that about the whole process of the installation.Including the boarc hardware drives
will be better.
Thank you very much.
    1. nfs problem,
    on the server, disable firewall, disable SElinux.
    try mount nfs to the server from another Linux PC.
    2. same program in different submenu
    some programs provide integration of several commands, eg, busybox, sash, tinylogin.
    there are standalone program, too.
    there are many options, depend on features and size.
    integration saves disk space, but dose not save memory space.
    for nfs mount, you should use the mount in busybox with nfs mount enabled.
    --- Quote Start ---
    originally posted by lonsta@Jul 20 2006, 10:46 AM
    />mount -t nfs -n -o nolock,rsize=1024,wsize=1024 192.168.11.17:/home/mxp/nios2 /mnt/nfs
    mount:rpc: unable to receive ;error = no route to host
    mount:nfsmount failed; bad file descriptor
    mount:mount on .168.11.17:/home/mxp/nios2 /mnt/nfs failed
    />busybox mount //it's okey,but added with the parameters
    //it got the same error msg like above.
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17036)
    --- quote end ---
    --- Quote End ---
    It looks like you have a problem on the command line. it reports:
    instead of:
    mount:mount on 192.168.11.17:/home/mxp/nios2 /mnt/nfs failed
    Not sure but you might check it....
    Thanks for your reply.
    When I config my kernel of "net" part(module), a problem puzzled me ,that is ..
    when I choose Networking options ----------->packet socket:mapped io ,an error occured : net/packet/af_packet.c file in line 1700.(I checked it ) ,a function ""vm_insert_page()"" does not declare
    it is in the function of packet_mmap();but when I disable(leave it blank ) this ooption ,make successfully.
    while configing kernel ,I refer to another book about arm linux kernel -compile .so I want to know the reason of this different ,what&#39;s this option for ?
    Thanks in advance. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    --- Quote Start ---
    originally posted by lonsta@Jul 21 2006, 11:17 AM
    thanks for your reply.
    when i config my kernel of "net" part(module), a problem puzzled me ,that is ..
    when i choose networking options ----------->Packet socket:mapped IO[/b] ,an error occured : net/packet/af_packet.c file in line 1700.(I checked it ) ,a function ""vm_insert_page()"" does not declare
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=17059)
    --- Quote End ---
    [/b]
    --- Quote End ---
    I&#39;m not expert with this sort of thing, but my guess would be that this isn&#39;t implemented on a uCLinux system. There are no "pages" to be inserted as we&#39;re dealing with an MMUless sytem.
    Cheers,
    - slacker
    Hello everybody, I am configuring the kernel for the DE2 board and there are ALOT of options and applications. How should I configure the kernel to make use of the DE2_NET project?
    --- Quote Start ---
    originally posted by bigpunx@Nov 8 2006, 02:30 AM
    hello everybody, i am configuring the kernel for the de2 board and there are alot of options and applications. how should i configure the kernel to make use of the de2_net project?
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19274)
    --- quote end ---
    --- Quote End ---
    Please start a new thread for your question. Use "new topic" .
