20 years agohow to build toolchain on linux ,no internet
Dear ALL beacuse i can't connect the Internet in my Linux computer. so i find many many error when i build the toolchain. first i read the script of build ,i find wget -N http:...
20 years agoDear hippo
I can run the Linux .But I only get the next information . <div class='quotetop'>QUOTE </div> --- Quote Start --- uClinux/Nios II Altera Nios II support ? 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 256 (order: 8, 4096bytes) Dentry cache hash table entries: 8192(order:3, 32768bytes) Inode-cache hash table entries: 4096(order: 2, 16384bytes) Memory available: 31256k/32768k RAM, 0k/0k ROM (714k kernel code, 423k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 NIOS serial driver version 0.0 ttyS0 (irq = 1) is a builtin NIOS UART Serial :JTAG UART driver$Revision: 1.4$ ttyJ0 at MMIO 0x810110F0(irq=3) is a jtag uart io scheduler noop registered io scheduler deadline registered Freeing unused kernel memory: 340k freed (0x40bc000 - 0x410000) init started: BusyBox v1.1.1-pre0 (2006.02.08-23:06+0000) multi-call binary[/b] --- Quote End --- I wait for a long time.but it isn't any other information. First I think the Linux maybe not run . so I enable LED task in the kernel confige. the task of LED can work. I think the kernel is running.i don't know why it can't printf other information . I check the information. I find it is different to your information . it is add the next information <div class='quotetop'>QUOTE </div> --- Quote Start --- Serial :JTAG UART driver$Revision: 1.4$ ttyJ0 at MMIO 0x810110F0(irq=3) is a jtag uart[/b] --- Quote End --- I wish you can give me help . Thanks you !.
