20 years agohow to build toolchain on linux ,no internet
Dear ALL beacuse i can't connect the Internet in my Linux computer. so i find many many error when i build the toolchain. first i read the script of build ,i find wget -N http:...
20 years agoHi Alex,
Please remove your old build dirs, cd ~/download,unzip build.zip,unzip build0207.zip, and run ./build0207 again. It seems you did not follow exactly (nios2 gcc should be 3.4.5 in my config, not 3.4.1). You should use the config files in build.zip. You should use the default minimal kernel config, only disable serial uart and change the console to jtag. Maybe you should open nios2 terninal first, then download vmlinux. I don't use altera's download cable or IDE. I know nothing about them.
