20 years agohow to build toolchain on linux ,no internet
Dear ALL beacuse i can't connect the Internet in my Linux computer. so i find many many error when i build the toolchain. first i read the script of build ,i find wget -N http:...
20 years ago[modify by alex 2006-2-25]
soory ! i mistake to do the next command <div class='quotetop'>QUOTE </div> --- Quote Start --- su - # your root passwd yum install compat-gcc-32 cd /usr/bin mv gcc gcc4 ln -s gcc32 gcc exit[/b] --- Quote End --- so now i have successfull build a toolchain in my Linux. //----------------------------------------------------------------------------------------- --- Quote Start --- originally posted by hippo@Feb 22 2006, 03:35 PM hi alex,
"redhat 9" is too old that "make" can not run properly.
please update to "fedora core 4", fedora.redhat.com .
you have select devel tools, install gcc32 as in the beginning of the buildroot guide, and do "yum update" .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12868)
--- quote end ---
--- Quote End --- Dear Hippo Thanks you for your help . now I have download teh "fedora core 4 " and install on my computer. but when i build it . if find have the next erros. <div class='quotetop'>QUOTE </div> --- Quote Start --- /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1405: warning: pointer targets in passing argument 1 of ‘md_number_to_chars’ differ in signedness /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1406: warning: pointer targets in passing argument 1 of ‘md_number_to_chars’ differ in signedness /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1407: warning: pointer targets in passing argument 1 of ‘md_number_to_chars’ differ in signedness /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1408: warning: pointer targets in passing argument 1 of ‘md_number_to_chars’ differ in signedness /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: In function ‘md_apply_fix3’: /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1664: error: invalid lvalue in assignment /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c: In function ‘nios2_check_overflow’: /home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15/gas/config/tc-nios2.c:1709: error: invalid lvalue in assignment make[3]: *** [tc-nios2.o] Error 1 make[3]: Leaving directory `/home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15-build/gas' make[2]: *** [install-recursive] Error 1 make[2]: Leaving directory `/home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15-build/gas' make[1]: *** [install-gas] Error 2 make[1]: Leaving directory `/home/wyouken/buildroot/toolchain_build_nios2/binutils-2.15-build' make: *** [/home/wyouken/buildroot/build_nios2/staging_dir/nios2-linux-uclibc/bin/ld] Error 2[/b] --- Quote End --- pls help me ! thanks!
