16 years agohow to build ptf for a neek
Hi
I am trying to set up linux on my neek board following nioswiki.com/InstallNios2Linux and nioswiki.com/OperatingSystems/UClinux/UClinuxDist I am at the step where a ptf file has to be specified in make vendor_hwselect. My question is : Is there prebuild ptf file for the neek board and where can i get it ? And also is there any tutorial teaching how to build a nios2 system for linux on a neek board using sopc ? -Adrien2 Replies
When you build your SOPC system and generate it, a ptf file will be generated for you.
actually starting from Quartus II v9.1 the ptf file won't be generated as I know. Instead a new xml file ".sopcinfo" will be generated which specifies how the system is constructed. The following package is a prebuilt NEEK system which I used to run uClinux on: http://www.nioswiki.com/@api/deki/files/115/=neek_ocm_spi.zip (source: http://www.nioswiki.com/operatingsystems/uclinux/mmcsd) I can also recommend you to go through the NEEK system architecture tutorial: http://www.nioswiki.com/nios_ii_system_architect_design_tutorial?gsa_pos=1&wt.oss_r=1&wt.oss=nios%20architecture which could give you a good starting point for developing own SoPC Builder systems for NEEK. Cheers, D.
