20 years agohow to build ext2 rootfs in EP2C35 (dev kit)
I would like to use a ext2 fs instead of a romfs for my rootfs I tried genext2fs, but it doesn't work. (pb with device file ??). When I boot , I have the followin message : "Freeing unus...
20 years agoExt2 takes a lot of space, and you should not use it on flash.
You should use the newer initramfs to replace romfs. Follow the link to build tools/kernel/apps. http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
