21 years agoHow to build applications
How do you generate a makefile with the "Create Make Target" and "build make target" functions? Every time I try it I get: make -k dhrystone make: *** No rule to make target `dhryston...
21 years agoOne other suggestion:
As I understand it, you're trying to setup a CF card as a writable filesystem in order to upload your apps for running? One of my favourite methods of running one-shot apps is to upload to one of the ram filesystems that are currently mounted. As an example, if you're using a full filesystem setup, then there should be 2 mounted ext2 filesystems that exist on ramdisks.# mount
rootfs on / type rootfs (rw)
/dev/root on / type romfs (ro)
/dev/ram0 on /var type ext2 (rw)
/dev/ram1 on /tmp type ext2 (rw)
proc on /proc type proc (rw)
sysfs on /sys type sysfs (rw) Notice the /var and /tmp lines. I usually perform a chmod 777 on the /tmp directory, connect via FTP using the "nios" and "uClinux" username/password combo, then upload to the /tmp directory. It's a quick a dirty way of running apps without rebuilding and reuploading the filesystem. If you want more info on the above procedure, just let me know.
