21 years agoHow to build applications
How do you generate a makefile with the "Create Make Target" and "build make target" functions? Every time I try it I get: make -k dhrystone make: *** No rule to make target `dhryston...
21 years agoI must confess you have me confused, I haven't looked too hard but am quite familiar with the Nios II IDE and I could not find the "Create make target" and "build make target" options you refer to. I think by far the easiest route for you is to follow the software tutorial which can be found as follows Help->Welcome select Nios II IDE and then select the Software Development Tutorial. It should not take you long and you should then be able to build download and debug your application
